nohurry wrote:
That came out good. You may still have to put slats, or rods etc at the front of the shelves. Otherwise the contents will end up on the floor when you open one of doors.
Thank you. I agree that I need something to help keep things from falling out. I wanted to get the bigger lumps out of the mashed potatoes first. Lol.
Yeah, that means, let's take care of the big items first, and we'll take care of the easier items later.- nohurryExplorerThat came out good. You may still have to put slats, or rods etc at the front of the shelves. Otherwise the contents will end up on the floor when you open one of doors.
- That also means I need to update the spreadsheet. The 3 sets total cost including state tax amounted to .... $8.52. Since we had a prior total of $11,291.63, our new total amount to $11,300.15.
By the way, the door frames were cut from a single 2 x 3 x8' piece of lumber, which cost me less than $3.00. I also used 1/8" thick hardwood plywood, which was about $10 a sheet. All totaled, those 3 doors probably cost me less than $10, not including the hinges.
Yes, if you pick your lumber carefully, 2 x 3's and 2 x 4's can be used for things other than framing. Just sayin...
Also, the plywood and 2 x 3's were bought a while ago, and have already been added into the spreadsheet, so I didn't need to add them here.
Getting ready for more cold weather this weekend - single digits tomorrow night, and snow Sunday into Monday.
Yea, I know, Bruce. That's a heat wave for you guys up in northern NY. Lol. - And they even work! Yay!
Yeah, I'll need to install latches to hold them shut. I don't have them yet.
- After a little drilling, and screwing, we end up with this! Wahoo!
- Yes, 3 of these doors.
- Sooooooo, I went to Lowes today, and bought a 3 sets of hinges for the doors I just made.
- I got my router out and proceeded to cut a groove on the backside of the frames I made, so I could put a panel in the center.
Then I cut some 1/8" thick plywood and glued them in place. Just waiting for the glue to dry.
- Well, I didn't end up where I wanted to today, but I did get some sanding done on the door frames. After spending some time sanding, I then rounded off the edges, both inside and outside on the top, or front edges, if you will.
I had hoped to get the panels cut and glued in today, but it just did not happen.
- Then it was a matter of applying glue and clamps, after making sure they are square, and by tomorrow the glue will be cured, and I can make the panel which will fit inside the frame rails.
I have 3 of these sitting, clamped, just waiting for the glue to dry.
38,782 PostsLatest Activity: Aug 30, 2026
