Cheryl_B's avatar
Cheryl_B
Anyone know how to add an outdoor shower to '94 Pleasureway?
I have a friend who just bought one and they love it but it has no shower. I thought there must be a way to tap into the water line from outside in one of the compartments, attach a connector of sorts and pop on a shower hose. Am I over simplifying it a bit? She has a:
1994 Pleasure-Way, Model VRL, 350 Dodge Ram chassis.
It's such a cool Class B. Was a single-owner unit, ordered from the factory and they just didn't get one with a shower. The head does not have a drain in the floor, so I guess it's not an option to put a shower in there.
Thanks in advance.
  • Thank you. I found a few things on youtube after posting this thread so I sent her those videos so she and her husband can get some ideas. I'll check your links too. Thanks for responding.
  • I tried to find it on the Transit Forum I read, but I know that a few cargo van conversions have used a shower curtain attached between the two back doors (opened) to create a shower "space", then used one of many different options for the shower itself. The simplest is a battery-operated handheld shower that gets placed in a bucket of warm water; but there are also gas-fired water heaters (or electric) that can be used for a portable shower
  • You just have to find a spot inside where there's hot and cold, like under the bathroom or kitchen sink, and connect to the supply lines with a Tee.
    You'll have to cut a good size hole in the wall so just make sure there's no stud where you cut.
