garryp
Aug 06, 2005Explorer
Budget/cost I coulda done a lot better.
Lifestyle I did ok. Solo traveler w/ dog, so I did not need the hassle of slides and their maintenance. I added Datastorm and computers, smaller portable EU2000 to supplement the monster diesel 10,000 watt genset (reasons: noise and efficiency), removed chair to make room for a computer desk, added a Wave6 catalytic heater, since I had electric stove added portable gas stove/broiler for non-electric use, added a Trimetric battery monitor, added XM radio, moved Dish equipment from house, and away I go. Could I have bought the unit with each of those features? Highly unlikely. And each of them is high on my list of needs.
Moral? Plan ahead of time any budget likely required to upgrade to your detail requirements, then buy the basic platform that matches size and budget of your lifestyle. Do not expect to get one out the shoot exactly as desired.
Notes for the LookyLou:
* I put the extra gas stove in the bay if not needed, on the dining table if needed, since there is only me to eat.
* I knew I would spend the $$$ for Datastorm before I bought.
* Wav 6 ((Wave 8 is a little too big) works great, much better than the noisy and inefficient furnace. In cool weather I shut door between rear and front, and place the heater where ever I am (back to sleep, front to do otherwise). And if you use the very small vent recommendations of the manufacturer, they are safe. I sleep with mine on.
* Regarding catalytic heaters, be wary of those with ODS (Oxygen Depletion Sensor). They may not work above 7,000 feet due to the thin air, which rules out the most beautiful parts of the West.
* I do not know how people survive without a battery monitor like the Trimetric or equivalent.
* If one is going to do extensive computer work, make necessary changes. Do not try to do it from your lap sitting on a sofa. That will drive you nuts if you are on the road for extended periods.
* And by all means, if you camp without hookups a lot, buy an enamel kettle to heat water on the gas range instead of the less efficient 10 gal water heater.
* And finally, do not buy without first checking propane tank capacity. I think that is easy to overlook. I have a 47 gal tank, and it is so nice to not have to search for accessible propane every time I move.
Darn, I didn't mean to say all that!
