wolfe10
Sep 20, 2013Explorer
Since you have a Cummins, I would also go with the Fleetguard ES Compleat OAT: http://www.cumminsfiltration.com/html/en/products/cooling/coolant/es_compleat/oat.html
If a Caterpillar, Caterpillar ELC: http://catoilandgas.cat.com/cda/files/760484/7/PEHJ0067-02.pdf
Both are basically "put it in and forget it" unless you drive more than 300,000 miles between changes in which case a one time additive is needed.
That way, if you are ever in for engine service, they will have the correct coolant on the shelf.
38,776 PostsLatest Activity: May 15, 2026
