wolfe10
Sep 21, 2013Explorer
unkledaddy wrote:Blaster Man wrote:wolfe10 wrote:
OK, have to ask-- why don't you want to run an OAT-based coolant. That is the high end coolant by Caterpillar and Cummins (Fleetguard) as well as others for their diesel engines???
I was wondering the same thing. The new stuff is good for years. I put propylene glycol in the Aqua Hot, not the Cummins.
I have a copper heater core. OAT corrosion inhibitors provide excellent long-term protection for aluminum and cast iron, but may not be the best choice for older cooling systems that have copper/brass radiators and heater cores, especially the lead solder used in them.
I wonder if this "don't use with copper/brass radiators" advice is current. I know there were initial issues with the OAT based coolants, but that was years ago.
Said another way, I don't know if this advice has basically become "an old wife's tale".
SOOO, here is current information from Fleetguard and Caterpillar websites:
http://www.cumminsfiltration.com/html/en/products/cooling/coolant/es_compleat/oat.html
Lifetime coolant with 300,000 mi, 500,000 km, 6000 hrs service intervals
Provides antifreeze and antiboil protection
Superior liner pitting and corrosion protection
Superior aluminum and solder protection
Compatible with gaskets, elastomers and other non-metallics in the engine
Optimizes cooling system performance and water pump life
Contains proprietary scale inhibitors
http://parts.cat.com/parts/machine-fluids/coolants/extended-life-coolant
Cat ELC is developed, tested and approved by Caterpillar to meet the same high standards as all genuine Cat parts.
Factory-Fill - Used as standard factory-fill for all Cat machine cooling systems.
Lower Maintenance Costs - Reduces engine coolant and additive costs by as much as 500% compared to conventional coolants. Cat ELC eliminates the need for supplemental coolant additives, extends coolant change-out intervals and reduces disposal requirements.
Advanced Metal Protection - Incorporates an advanced formula technology with organic acid additive corrosion inhibitors, such as a combination of mono and dicarboxylates for maximum protection of copper, solder, brass, steel, cast iron and aluminum.
38,776 PostsLatest Activity: May 15, 2026
