FIRE_UP
Aug 28, 2013Explorer
Don,
Thanks for your insight on this. May I ask, which system you used? Was it the Costco one or, another unit like it? The Costco one has a dual cartridge setup so, I'm not sure of the time frame for the amount of washings it will give before it must be replenished. I'm new at this so, still learning. One thing the DW read was that some folks are washing and rinsing with regular water and then, rinse again with the deionized setup so as to not waste it.
Seems like kind of a pain to do it that way but, I suppose I would get used to that procedure if, the system worked and, it prolonged the chemicals/pellets/whatever is used. A deionized system sounds on "on the surface" so to speak but, I'd sure like to see one in action on something like our coach before committing.
Scott
On edit: MRUSA,
I was tying my response to Don when you entered yours. That's the EXACT info I was looking for. A hands on user. At this point, I think I'm going to order one up. Thanks for your input here.
Scott
Scott
On edit: MRUSA,
Scott
38,777 PostsLatest Activity: May 24, 2026
