Golden_HVAC
May 09, 2014Explorer
coffebreak wrote:
would u feel safe walking around in this? is this safe?">is this safe
Are you worried about it tipping over in a wind storm? Probably rocks less than one that is not jacked up off the ground.
If one rear tire is off the ground, then the parking brake will not stop the other tire from spinning. Even leaving the RV in park, with one tire off the ground will not keep the vehicle still.
The RV is stable. The only problem that I can foresee is if the hydraulic line from a single front jack to the controller springs a big leak, then it can tilt to one side. Thus a reason to put 6X6 block of wood about 12" long under each tire, so it does not tilt to much to one side if one hydraulic line should break, or one of they front seals fails and leaks down over time.
Fred.
