kmb1966
Jun 21, 2018Explorer
A Good Cigar wrote:
KMB, do you live in an area with very high summer temps? I have an Onan 5500 watt in my 2000 Suncruiser, and being in the Phoenix metro area with zero chance of seeing freezing temperatures, I run straight 30wt oil in it. Several summers with it running during the drive in temps well over 100° and no hiccups. I can't imagine that your 7000 watt has to even break a sweat to power a 30 amp coach! If it was a 50 amp coach it would also have the 7000 watt option, and the same cover and ventilation, so I'd be concerned about the replacement generator having the same problem!
Is code 37 for overheating?
We live in Louisiana. Going thru Texas and Arizona last year, the generator would overheat (or maybe vapor lock) at times. Would run fine after temps were under 95. I do run 30wt oil. I agree with you, and I am too concerned that the new replacement unit will also have the same problem. Onan talks about a heat/shield to direct the heat away from the unit toward the rear. I hope they know what they are doing.
I think code 37 means: See your Onan dealer!
38,769 PostsLatest Activity: Apr 24, 2002
