valhalla360
Jul 22, 2014Navigator
Tom N wrote:
Diesels are preferred at altitudes >10,000'. Because of the turbocharger/blower.
-Tom, W3TLN
This along with an exhaust brake is the significant difference. If you will spend a lot of miles in the mountains, it can be justification.
Torque only determines if you get up the hill and that is torque at the wheels. A lower gear will provide more torque, so as long as the engine isn't grossly underpowered, torque is a non-issue.
How fast you can go up the hill is mostly about HP. The only catch is people get nervouse running a gas engine at high RPM in a torque producing lower gear. Assuming the engine is in good running order, it won't hurt the engine.
Unless you are a carney putting 50-100k miles/yr, long term durability of a diesel is a red herring (even then it's probably overstated with newer diesels being much more complicated). With proper care, a gas engine should be good for 200-250k miles and odds are the rig will be old and falling apart long before the engine gets worn out.
