DanTheRVMan
Jan 20, 2015Explorer
bluwtr49 wrote:
Going out on a bit of a limb here but if you look through the multitude of posts on this subject you may notice that two brands stand out when the variety of different issues are discussed. Since both of these tires are supposedly designed specifically for the RV market it would suggest that the brand of tire you happen to be running may be more sensitive than others.
You might also form the opinion that if tires are going to be replaced on a time schedule it might be wise to buy the least expensive as possible since the incidence of failure appear to less than the high priced items.
1. why not name a brand instead of having everyone guess or search?
2. Not sure which brand you think is the problem but all tiffins come with michelin. I really have not checked other brand mh tires. But what ever has the largest market share will also have more tires out there under inflated by owners and more failures posted on forums. Simply looking at lots of brand X failures is overly simplistic without looking at other parameters.
Not trying to endorse or detract from michelin as I do not know which tire is best or worst.
38,773 PostsLatest Activity: Apr 25, 2026
