J-Rooster
Jan 20, 2015Explorer
I've been RVing since 1976 and of yet I never had major tire problems. I'm not into all the technical gadgets etc. I air my tires at 100 psi before I head out on a trip and before I return from a trip and that is it. Same as when I was driving a Semi. Just as important is other tire care that no one else is talking about. Your rubber tires are very sensitive to road dirt and grime, heat, cold, moisture, going over curbs and holes in the road surface, overloading, dirt roadways, and I see this at every campground I go to RV's up on blocks and the block surface does not cover the complete tire surface which can result in inner side wall break down and damage which you can't see. Great Question
38,773 PostsLatest Activity: Apr 24, 2026
