Raymon
Jan 20, 2015Explorer
To Bikeboy57,
You stated "Moisture is the enemy of the steel belts." How does the steel belts become exposed to moisture when the belts are vulcanized between layers of rubber? In my opinion the steel belts only become exposed to moisture due to tire wear. If the belts become exposed they will rust which is not good. Also, steel belts exposed to brine created from applying salt to the roads during winter, not only rust, but corrode very quickly.
You also stated "Driving the tire and getting it up to temperature dissipates the moisture,..." What moisture are you referring to?
Ray
Ray
38,781 PostsLatest Activity: Jul 20, 2026
