WILDEBILL308
Jan 20, 2015Explorer II
One other thing that I didn't want to add to the above reply as not to confuse anyone. Be Shure your tiers are of the right load range. This is a problem if you are at the top off the weight range for your tiers. I had a problem with a Class C I had. The front tiers kept having problems including a couple of blow outs. The coach was well under weight. I finally figured out the problem. The manufacture had used the stock tiers that came on the van chasse it was made on. The original 16 in load range D tiers were overloaded from the get-go. I moved up tp load range E and solved the problem.
The other big thing not mentioned is speed rating. When looking at tier manufactures web sites I was surprised to find some only rated for 60 mph some 65 yes there are 75mph rated tiers.
Bill
Bill
38,780 PostsLatest Activity: Jul 20, 2026
