rgatijnet1
Jan 21, 2015Explorer III
JimM68 wrote:rgatijnet1 wrote:JimM68 wrote:
I set the alarm on my tpms to 75% of my cold tire pressure. When / if the tpms alarmgoes off, I stop.
Are you saying that when your tires which would have a 100psi cold tire pressure leak down to 75psi, you stop? In other words 25 psi below the minimum cold tire pressure.
You're kidding, right? :h
I am not kidding. My tires do not lose any air, not ever, unless a failure is in progress. I do of course monitor the TPMS always. The air pressure on these tires fluctuates a LOT. Depending on outside air temp, and if the tires are hot or cold, pressure changes are crazy.
In this bus, with the new sumitomo's I put on a few years ago, I only have needed to put air in the tires in the spring coming out of storage. I credit that to getting rid of the extenders, they've been known to leak...lol. just a bit. sometimes...
I'm not running around chasing my air pressures. 110 / 95 cold tires at 70 ish ambient is good. All the fluctuations, I don't chase them.
I understand what you are saying but it just does not make sense to me. IF you got a small leak from a nail, by the time your TPMS let you know about the problem at 25% below minimum, and if it was on a dual tire, the weight would have been shifted to the other dual for a lot of miles, which would probably permanently damage that tire as well. Seems to me that a 10% range of tire pressure would be sufficient to let you know that you had a problem and still be able to stop in time to protect the other tire.
38,781 PostsLatest Activity: Jul 20, 2026
