Tireman9
Jan 26, 2015Explorer
Jim, My point was that when the pressure has dropped 20% from the inflation needed to carry the load you are doing damage to the tire.
Given that when driving the tire pressure will be 5% to 10% higher than your set pressure. You should be able to set the TPM warning at as little as 5% below the set pressure and never get a warning when running unless there is in fact an air leak.
38,781 PostsLatest Activity: Jul 20, 2026
