tenbear
Oct 27, 2014Explorer
cgmartine, thanks for the follow-up report. Glad you have the inverter hooked up. Every class C is different so I'm not surprised your hook-up is different.
What size wire did you use? The longer the 12v wires, the larger they should be to limit the voltage drop. If you didn't put a fuse in, you might consider putting a fuse in the positive wire close to the battery, just in case.
38,766 PostsLatest Activity: Jan 10, 2026
