10forty2
Mar 06, 2017Explorer
Can you verify with a meter that there is actually voltage present at the water heater element? If not, then there's definitely a switch or breaker or fuse or even a broken wire keeping the current from getting to the element. If there is electricity present at the connection to the element, then the element itself is most likely burned out.
