Gjac's avatar
Gjac
Explorer III
Jun 12, 2015
Attwood WH switch causing 15 amp fuse to blow
Wife took a hot shower fine, I tried but no power to the water pump. Found blown water pump fuse 15 amp and replaced it. It blew again and I had no lights above the stove for level readings. Found blown 15 amp glass fuse in back of hood and replace it. I have narrowed the problem down to the water heater. When I turn on switch the water pump fuse blows. What would cause this to happen? Any help would be appreciated I M currently in Ohio traveling out west.
  • I would check for any loose wiring at wire connections locations and tighten them.
