cochise49
May 05, 2014Explorer
Had HWH levelers for 10 years then got a new rig with LCI. Never a peep of trouble from the HWH but the LCIs failed first trip out. Pump has been replaced so we'll see.....off subject though. In the leveler manual there is a procedure for manually retracting the jacks. HWH requires a ratchet on a shaft that may be difficult to turn due to being too close to a wheel. LCI has two methods...one enables you to use an electric drill and socket. I never wiped down the jacks on the HWHs and one stuck on me at the ten year mark. Thought it was a weak spring but I wiped the extended shaft off with a rag and it worked fine.
