tropical36
Nov 17, 2016Explorer II
JimInMich wrote:
Here are some pic's taken from the John Deer Chassis manual I have for this GBM. Does it look like the GM autobrake?
Very interesting and like nothing I've ever seen.
The top diagram looks something like the power wheel brake booster and much like GM which uses the power steering pump combo, rather than a vacuum diaphragm.
The middle part of the drawing definitely shows something other than a manual parking brake control, but doesn't look anything like GM's.
The bottom showing the cable actuated drum, I'm not sure where this drum is and guessing that it's on the driveshaft.
So, do you have a drum at the rear of the transmission on the drive shaft?
Do you have any indicator lights in your display that says auto anything?
Do you have a park position and does it do the same thing as the knob shown?
Do you have a manual foot brake or handle as well?
With the ignition on and actuating the brake (engine off and out of the park position) can you hear any kind of a pump running that might indicate the release of this brake or must the engine be running for the rig to free roll?
