Cindy_and_SteveExplorerOct 23, 2021Automatic air tank drain valvesI tried to drain the water from the air tanks on our RV and I couldn’t find the drain valves. No valves to turn and no lanyards to pull. On the tanks, where drain valves should be, are some sort of gi...Show More
donkeydewExplorerOct 23, 2021google 12 volt air dump valves and you will probably find the one you are looking at on your tanks
Related ContentHouse battery drainAutomatic Transfer Switch (ATS)Barker Automatic valve openersTank drain valvesLow point drain valve question
