Cindy_and_SteveExplorerOct 23, 2021Automatic air tank drain valvesI tried to drain the water from the air tanks on our RV and I couldn’t find the drain valves. No valves to turn and no lanyards to pull. On the tanks, where drain valves should be, are some sort of gi...Show More
wolfe10ExplorerOct 24, 2021AND, what chassis. The air tank drains are part of your chassis, not coach.Thanks.
Related ContentHouse battery drainAutomatic Transfer Switch (ATS)Barker Automatic valve openersTank drain valvesLow point drain valve question
