JRscooby
Oct 24, 2021Explorer II
Cindy and Steve wrote:
Yes it dumps the air before it starts to level. I hadn’t thought of that. Those things I’m looking at must have something to do with that. So if they are some sort of electric air dump valves then I suppose I don’t ever have to worry about draining the water out as long as I use the automatic leveling system once in a while. Does that sound right?
No, that does not sound right to me. To be fair, I have zero experience with air systems on MHs so what I say could be called trumpism.
OTOH, for well over half a century I have drove, repaired rebuilt trucks.
For most of that time, part of drivers daily maintenance was drain any water collected out of tanks before it could cause issues. As long as there where owner-drivers, that worked great. But because failure to drain tank is unlikely to cause issue the first day, slip-seat operations, where you are unlikely to drive the same truck 2 days in a row, demanded something that worked without driver input. So auto drain valves, and then air dryers became normal.
The reason I say using leveling system, (or any other system) to drain the tank, (assuming you are draining to make sure system is dry) is because for water to get out of the tank it must go thru all the lines and valves on it's way out. Once it does that water is in everyplace you do not want water to be.
