Cindy_and_SteveExplorerOct 23, 2021Automatic air tank drain valvesI tried to drain the water from the air tanks on our RV and I couldn’t find the drain valves. No valves to turn and no lanyards to pull. On the tanks, where drain valves should be, are some sort of gi...Show More
MT_BOBExplorer IIOct 24, 2021Heated automatic drain valve is what it looks like. What is the make/name on it?
Related ContentHouse battery drainAutomatic Transfer Switch (ATS)Barker Automatic valve openersTank drain valvesLow point drain valve question
