MountainAir05
Feb 22, 2018Explorer II
this link is for 4 zone RV system. This is for a Dometic system.
http://www.forestriverforums.com/forums/attachment.php?attachmentid=28112&d=1366084072
My home AC/Heater works the way you want but will not work with another system. Heater/AC units mother board talk to each other and the thermostat. I have not seen a rV system that does that.
Doug, system work just like you want, if you set the hot/cold temp to close you could get what you said. I would have to go look to get the temp balance numbers, but that also is build in so you would have to over ride the numbers to get a conflict. Just two weeks ago here, we had a February warm up. House got up to 78 and AC came on cool it back down to 76. We had this happen several days. No one touch the thermostat. Our heat is set to 72/73 if a lot of wind.
38,782 PostsLatest Activity: Sep 10, 2026
