dougrainer
Feb 23, 2018Nomad
chuckftboy wrote:
Since residential thermostats are designed 24 volt ac you would need to use one that has alternate battery power as DrewE said. Motorhome thermostats are designed for 12 volt dc operation. I have 2 heat pumps and 2 furnaces so in my case, I would need 2 thermostats, one for each a/c furnace combination. Also most newer motorhomes use remote sensors and home thermostats typically sense at the thermostat, making location difficult.
To answer Doug's question. Modern home thermostats have a 3rd selection "AUTO" for auto change over from heat to cool with a built in differential between the heat and cool setting of no less than 2 degrees differance. If heat is set to 70, cool can't be set lower than 72. Referred to as the thermostats "dead zone".
I have AUTO also in my home. But that is to control the whole house blower fan. You set to Auto and the whole house fan shuts on and off with the tstat when met. If you put on FAN, the whole house fan runs all the time and the AC/HEAT just quits running. I also looked up the hi dollar NEST home tstat for $250. IT also does not have the capability of auto switching between Heat and COLD. You MUST tel,l it HEat or Cold. Doug
38,782 PostsLatest Activity: Sep 10, 2026
