Dale_Traveling
Feb 25, 2018Explorer II
Since my coach uses a single thermostat controlling a roof A/C and a propane furnace changing out the original Coleman for a residential automatic change over was pretty easy.
Honeywell RTH5100B
Powered by 2 AAA batteries that last a year. Non programmable but will do auto change over for heating and cooling. In auto mode the preset heat and cooling temps must be separated by 3 degrees. No over lap. High temp for heat of 68 and a low temp for cooling of 71 as an example. I have mine set to 68 and 78 which has worked well.
Any owner considering the option will need to dig deep into the capabilities and limitations of any thermostat they are considering and the need to match it to the HVAC hardware installed in the coach.
Honeywell RTH5100B
38,782 PostsLatest Activity: Sep 10, 2026
