FIRE_UP
Jul 10, 2016Explorer
maddawg46 wrote:
Bought my first motorhome . It's got auto leveling. Using level at the fridge, it looks pretty much dead on. If it wasn't, what would you do? Level using manual? Saw no book in the coach on the auto jacks.
Maddawg46,
As others have stated, we need more info on your coach, make, model, leveling system and, if you have a particular model or number of that leveling system. For instance, our coach, an '04 Itasca Horizon, 36GD came with the HWH, 625 Computer Controlled Automatic Leveling System. And, with that system, there is no HOCKY PUCK for adjusting the leveling system.
There is however, a master control panel, under the coach, located in front of the right front wheel, under the steps. It has an independent, floating control board, inside that panel. It's adjusted from the outside, using a specific set of wrenches and screwdriver. IT won't do any good to explain how to adjust it, if yours is not the same system so, this is why we all need more info, to help you get a better grip on what's needed for adjusting yours.
Scott
