kalynzoo
Mar 05, 2016Explorer
You don't mention what you are traveling in. Anyway, the Grapevine (I-5 between Valencia and Bakersfield) is you one really big climb and drop. Any well maintained RV should handle it without a problem. If you have an older rig, turn of your engine Air Conditioner before starting the climb. Don't let the engine overheat, so keep your revs at a normal rate and enjoy the scenery. Going down on the other side watch your speed, don't let your speed get beyond your comfort level, and tap your brakes as needed to keep your speed down rather than trying to stop when going too fast. I usually keep my downhill speed at about 45 to 50 mph. It really isn't a bad drive at all.
If you are really concerned, or just uncomfortable, then take the lovely drive straight up highway 101. You will still have a few grades to deal with, but they are shorter, not necessarily flatter. Camarillo grade (steep down run), and Atascadero grade (short but steep up and down). The drive up the 101 is by far more scenic, but it will add at least an hour to your trip, probably more as traffic will be much slower. Again, if your rig is in good condition, the Grapevine should not be a problem.
Happy Trails.
Happy Trails.
