I have a 2007 Winnebago voyage with weather Pro power awning. the problem is it will not come in on one push of the button, Have to hold button till it stops then wait 20 seconds and hold button again...
2007 should have the control box. There are 2 wires at the control box that go directly to the awning motor. You hot wire those 2 wires and operate the awning in and out. IF the awning stops and then resumes after a short wait, the motor is bad and needs replaced. IF the awning motor operates without stopping by hot wiring, then there is a problem with the control board or the 12 volt supply to the control board. Doug
