SuicideCharley's avatar
Apr 06, 2015
Awning repair assistance
What is the part called that slides into the long horizontal bracket mounted on the wall from the awning? It keeps the awning attached to the wall while it unrolls. I think mine is missing and can't find any info on it via google.
  • If there is no bead on the awning fabric look in the channel you may have fabric that is old and has torn leaving the bead in the channel. At that point its time to replace the fabric Good luck
  • CG Dawson wrote:
    Charley, I think you are describing the bead that is permanently attached to the awning and slides into the channel at the top of the sidewall. The awning bead is usually held in place with a small screw screwed into the channel at each end of the bead. Sounds like it has somehow come out of the channel slot.
    Yes that is exactly the case. But it appears that there is no bead on the awning material. Nothing for it to slide into the rail. I'm attempting to try and find this "bead" to replace but not having much luck. Maybe I will now that I know what it is called lol. THANK YOU!
  • Charley, I think you are describing the bead that is permanently attached to the awning and slides into the channel at the top of the sidewall. The awning bead is usually held in place with a small screw screwed into the channel at each end of the bead. Sounds like it has somehow come out of the channel slot.
