While in Colorado 3 weeks ago a high wind came up and ripped about a ft of awning material away from the sewn bead flush with the Al extrusion that holds the awning in place. Has anyone been successfu...
i removed the drip rail and put the material under the rail used the rail as a clamp to hold it screws right thru the material used 3M polyurethane in the screw holes to make sure everything was water tight
