NewbRVerExplorerJun 07, 2015Axle shaftsHello, I just bought an 83 Pace Arrow. It was towed here and the axle shafts were pulled out of it. I went to put them back in. The first one went in without any issue, a bit of wiggling back and ...Show More
IvylogExplorer IIIJun 07, 2015Should slide back in. On a heavy shaft I've had to put a pair of vise grips on the bolt flange to help lift the splined end up.
Related ContentEaton 17,000# axle shaftReplacement WDH shaftDrive shaft disconnectDrive shaft lock outDrive Shaft Disconnect
