NewbRVerExplorerJun 07, 2015Axle shaftsHello, I just bought an 83 Pace Arrow. It was towed here and the axle shafts were pulled out of it. I went to put them back in. The first one went in without any issue, a bit of wiggling back and ...Show More
JimM68ExplorerJun 11, 2015That is very definitely absolutely a GM Rochester Quadrajet Gasoline carb.For now, I'd just ignore the propane stuff around the engine, concentrate on getting her running on gas and moving under her own power.
Related ContentEaton 17,000# axle shaftReplacement WDH shaftDrive shaft disconnectDrive shaft lock outDrive Shaft Disconnect
