aboeck3
Oct 07, 2017Explorer
B20 okay
I have a 2017 MH with a Cummins engine. Is B20 fuel okay to use?
SidecarFlip wrote:
Just my experience in the past but I'd be careful with B20 Biodiesel, especially if you plan on leaving it sit in your fuel tank(s) for an extended period of time.
It has a very bad tendency to grow algae when it sits unused in a fuel tank and it's very expensive to remedy. Lets just say I found out the hard way and I did most of the mechanical work myself, new fuel (lift) pump, new fuel bowl, new injectors and new fuel level gauge and pickup in the fuel tank plus a lot of flushing the system and a lot of cussing too.
If you use the unit all the time, no issue but, if it sits alot , B20 can become a big and expensive issue. Even with regular ULSD, I run a biocide in every tankful, winter (when it's sitting idle) and summer, when I'm using it.
Little heads up...
