Mr__Coach's avatar
Mr__Coach
Back up camera
It appears that my back up camera in my 2000 dutchstar is bad. The monitor appears to be working but no picture. I discovered that there is 12v power going to the camera but no signal going back to the monitor.. I have the camera in at a test shop to try an see if the camera is working and possibly try fixing it, if not I don't know what to do. You can't get a replacement camera so I'll have to go with an entire different system and possibly hard wire the unit in through the existing wire. Anyone have problems with their cameras not working, what did you do as far as replacement?? Thanks
  • Call Tim RV Cams, Inc ------ 877-378-2267 When I thought the camera in our American Dream was bad Tim got us on the road. Great product,
    Greater service. As it turned out it was the monitor not the camera, even though the light on the monitor was on. Call him, you will not be sorry! Bill
  • Mine quite and I found that Costco online had a good replacement for only $200.00. it works quite well but you will have to run new cable which is included.
  • If not parts, then replace the camera. As you have stated , then replace the system
