O.K,…so, I pulled the rear marker lights to see if I could get to the camera conduit. Lo and behold, the lights wiring was chewed through, also.
I couldn’t get to the wiring, so I opened it up a bit with a hole saw. A bit.
I managed to get to all the light wiring, and in the process I found the camera cable. It routes straight down through the back wall to the underside. There was some slack below, but I couldn’t pull it up.
The lights I can rewire easily. But, I tried splicing the camera connector and could not get the camera to work. Either it is severed in another location, or there is some trick to the splice that I’m missing.
Effing fat ruckers! This is more fun than a colonoscopy.
:M
