My 2014 Jayco Redhawk came with a backup camera mounted in the rear-view mirror that only comes on if the RV is put in reverse. Can this camera be modified so it will stay on while I am driving. I wil...
Camera could be wired to the reverse lights. Quick fix if that's the case is to grab 12 Volts from the running lights instead and just turn on the running lights when you want to have the rear camera on. Otherwise you will have to run 12 volts all the way back there with a switch so you can turn the camera on and off from the cab.
