johnhicks's avatar
johnhicks
Bad repairs
Please allow me to ventilate. I'm somewhat freaked out.
We went to a shop last week to have the cracked Cummins exhaust manifold replaced. I could clearly see the crack, no doubt.
The tech broke only one bolt which is amazing on this 23-year-old engine. But that's not the point.
I asked him to check out all the soot on the exhaust brake housing and he found that someone had simply welded/repaired the brake adaptor tube to a backing tube and had _turned it around_ and _stuck it into_ the exhaust brake housing. No clamp, no bolts, no nothing.
That explains a few things!
  • Wow. I kid you not, I've heard of somebody stabilizing a brake pad with duct tape. Glad you found your problem. :)
  • I looked around for my duct tape but all I could find was the silver tape...
    The shop ordered a new adaptor tube and clamp and installed it, no big deal and not expensive.
  • At least you found the cause of the soot on the exhaust brake housing.
    Did you get it repaired or just duct tape it on place. :B
