tropical36
Jun 30, 2017Explorer II
jyrostng wrote:
I recently bought a 2000 v32 on a ford F53 chassis with 102,000 miles on it. One of the first thing I did was change the 12yo Bridgestone tires, I decided on Hankooks They looked good and were $225 each 2.45x75x19.5. After they were on, I found out they were 2 years old on the dot,separate issue. I had vibrations I finally couldn't live with on our first trip to Loffland, Nv.
The new tires had been balanced with lead clipped on the rim. I suspected bent steel rims, I wasn't there to observe the balancing and see how much the rims were off. When balancing a tire, if the rim is warped, the balancing machine sees this as a out of balance and adds weight so the machine eliminates it.
I had a new spare, it had never been on the ground, I figured the wheel was straighter. I bought a new matching tire and had it mounted on that rim, when they did it, they used 6 oz of beads inside the tire to balance it. When I thought about it, that's a much better option with steel rims than having a machine actually make the tire statically imbalanced by compensating for the warp with lead weights.
just wanting others opinions, I'm not buying aluminium rims or even replacing these accuride steel rims that cost $300+ each.
I've been told by tire experts, that computer balancing on the front is best and not to even bother with the rears, so.....that's where I'm at now and so far, so good.
