RLS7201
Aug 31, 2019Explorer II
NRALIFR wrote:RLS7201 wrote:NRALIFR wrote:camperdave wrote:RLS7201 wrote:
Beads will only do STATIC balancing. For front tires you need both STATIC & DYNAMIC balancing, which can only be accomplished with a spin balancer.
Richard
I don't understand what you mean. what is the difference in static and dynamic balancing? Seems like beads in the tire are by definition dynamic, as the wheel is spinning as they find their home.
It means he doesn’t understand physics. Beads/Centramatics ARE dynamic balancers.
No It means you don't understand tire balancing and physics.
Would you care to come out from behind your keyboard and insult me to my face, big guy? Or are you just a keyboard bully?
Static balancing is what beads and bubble balancers do. Dynamic balancing is the balancing of the tire from side to side, not top to bottom. Dynamic balancing is one of the causes of death wobble and cupping tires.
Here go educate yourself
I watched your video, and I have no problem with what he’s saying because he’s demonstrating the modes of a computerized spin balancing machine. One of the modes is “Dynamic”. He says nothing about any type of dynamic balancing media.
If you’re under the impression that a spin balancer is the only thing capable of dynamically balancing a tire, you’re wrong. I’ll say it again, you don’t understand physics, and I suspect you don’t understand what the word “dynamic” means either. If you did, you’d know that saying “Static balancing is what beads and bubble balancers do.” is half wrong (guess which half), and “Dynamic balancing is one of the causes of death wobble and cupping tires“ is completely wrong (it should be “Dynamic imbalance is....”.
BTW, the balance problem he was illustrating with the big, wide, off-road tire can be easily fixed with dynamic balancing beads. Provided the problem is strictly a balance problem, and there are no physical defects or damage to the tire or wheel, beads will balance it. No dynamic balancing media can fix a bent, warped, out of round tire or wheel. But then, lead weights can’t either. Even if a computerized spin balance machine is used.
Or never mind, ya can't fix stupid.
Richard
38,778 PostsLatest Activity: Jun 05, 2026
