map40
Sep 02, 2019Explorer
Beads or centramatics function the same way. If you want them 2 automatically balance while you're driving down the road, that's what they were designed to do. Between the two the safest option is centramatics because it's not in the tire, you can still balance the tire, and it will stay with you even if you change tires.
The beads works just as good but once you put them in the tire you can no longer spin balance them. Also, you can't reuse them and some tire shops will tell you that they're bad and they need to be taken out.
You can spin balance them, which is what most people do. This is not as efficient and you might get a shorter thread like, if you care about that at all.
The best option is 2 Road Force balance the tire using a Hunter 9700 balancer and then install cinematics. Just be aware, for most of us, this would be an overkill. Long distance haulers do this, and they can get 3 to 400k miles on their routes with re- threading thanks to this practice
