Does the beads work alright in the front tires to balance? They are going to mount the front ones tomorrow, but have no way to balance besides the beads. And the beads come with the new valves. What t...
Bead will need a special valve stem to keep the beads from plugging it, and beads will need to be replaced each time you put on new tires. IMO I feel the though the cost is higher up front that the Centermatic balance rings are far better. Not only do they balance the tire and rim, but the whole drum/rotor and hub assmy. and can be used over and over again as new tires are put on.
