Octaneforce wrote:
Correction. I just went out and looked. Mine is rear disc.
Then you need the larger ball joints. Be careful because the mistake that almost cost us our lives was the parts guy saw HD ball joints listed under the drum brakes thinking if they said HD they must be better, but the tapered shaft is slightly under sized.I don't want to write a novel here but if you want to see the details look in the archives 2 years ago under Gjac. I ended up using the MOOG ball joint purchased from Henderson.
