timmac
Nov 18, 2018Explorer
T18skyguy wrote:
Nobody has mentioned one of the best gear train mods you can get. Double your available gears with a Gear Vendors overdrive
That is money well spent. If you get the Banks, you need to torque the bolts correctly, then re-torque again after a couple trips. There is no gasket used or needed on the headers.
Gear Vendors will not work on the new 5 or 6 speed torque shift Ford trans, I did check it out, not sure if it also works on the Allison as well, I suspect as more gears are added to the new transmissions Gear Vendors wont be selling that product anymore.
