T18skyguy
Nov 18, 2018Explorer
timmac wrote:T18skyguy wrote:
Nobody has mentioned one of the best gear train mods you can get. Double your available gears with a Gear Vendors overdrive
That is money well spent. If you get the Banks, you need to torque the bolts correctly, then re-torque again after a couple trips. There is no gasket used or needed on the headers.
Gear Vendors will not work on the new 5 or 6 speed torque shift Ford trans, I did check it out, not sure if it also works on the Allison as well, I suspect as more gears are added to the new transmissions Gear Vendors wont be selling that product anymore.
I wondered that myself. That unit was a godsend in the days of the 3 speed and 4 speed transmissions. They sell plenty of them for dragsters and all kind of applications. They'll be in business, but less for Ford and Chevy stuff.
