timmac
Nov 28, 2016Explorer
Chum lee wrote:
Simple gasoline engine air/fuel stoichiometry says you need 14.7 lbs of air to 1 lb. of fuel. If you add more air, then you need to add more fuel or you will generate a lean condition which will raise exhaust gas temperatures and eventually cause engine damage. If you add more fuel than necessary, then you generate a rich condition which wastes fuel and reduces mileage. Engineers/chemists know this. I guess the rules of mathematics and chemistry don't apply to everyone else.
Chum lee
Yes that is true on the surface but more HP and Torque also means the motor works less to get up that big hill when we are talking about a 20,000 lb motorhome, so there can be gas savings in certain times with the Banks Power Pack System..
