holstein13
Sep 04, 2015Explorer II
Tom/Barb wrote:Tom/Barb, you may be able to enable this feature. To use it, you must download PowerSpec directly from Cummins and enable the "PTO Feature." Alternatively, you can stop by a Cummins distributor and they can plug in and enable it.
My cruise control will not set high idle, thus, I never use it.
I know you are asking yourself what the PTO has to do with our coaches since we technically don't have a PTO but that's what's connected to your cruise control when you are in neutral. By hitting either the set or resume button if the PTO Feature is turned on, it will set the engine to the minimum RPM set in the PTO section of your engine parameters.
