lc0338
Sep 04, 2015Explorer
holstein13 wrote:lc0338 wrote:This looks very interesting and plausible. So the real question is how high of an idle is high enough? And does it make a difference in our application?
Picked this off a diesel forum:
The purpose for high idle is to avoid a condition called wet stacking. An engine at idle does not create high enough cylinder temps to atomize the entire amount of fuel being injected into each cylinder causing the unburned fuel to mix with, and wash down the oil from the cylinder wall, thus dilluting the engine oil with diesel fuel and causing excessive engine wear. All class 8 and 6 engines have had the ability to raise the idle through the use of the cruise control since their conversion to electronic engine controls, and most manufacurers recomend a minimum of 1,000 rpm for extended or prolonged engine idle periods. On my 06 automatic truck, when the temps are low enough it will idle up to 1000 rpm after 3 minutes at base idle, or I can engage the high idle by pressing the cruise button on then pressing the resume/set side, it will instantly jump to 1,100 rpm, if I continue to hold the resume/set button the engine rpm will continue to rise to 1,500 rpm and stay there until I disengage the cruise with the on/off button, or step on the brake.
Here is information from my 2014 Ram 5500 owners manual about high idle feature (Automatic transmission only)
* The Idle-up feature uses the speed control switches to increase engine idle speed and quickly warm the vehicle's interior. This feature must be enabled by your dealer. See your local dealer.
* With the transmission in PARK, the parking brake applied, and the engine running, push the speed control ON/OFF switch to on, then push the set button.
* The engine RPM will go up to 1100 rpm. To increase the RPM, push and hold the RESUME/ACCEL button and the idle speed will increase to approximately 1500 RPM. To decrease the RPM, push and hold the SET/DECEL button and the idle speed will decrease to approximately 1100 RPM.
* To cancel the idle-up feature, either push the cancel switch, push the ON/OFF switch or push the brake pedal.
My high idle is activated and my tranny also has a PTO so I suppose that 1100 RPM is adequate for making sure the excess fuel gets burned off and the availability to increase RPM to 1500 RPM is to support the PTO and it's use.
Here is what the manual says about engine idling:
Avoid prolonged engine idling. Long periods of idling may be harmful to your engine because combustion chamber temperatures can drop so low that the fuel may not burn completely.
Incomplete combustion allows carbon and varnish to form on piston rings, engine valves, and injector nozzles. Also, the unburned fuel can enter the crankcase diluting the oil and causing rapid wear to the engine.
If the engine is allowed to idle, under some conditions the idle speed may increase to 900 RPM then return to normal idle speed. This is normal operation.
