holstein13
Sep 08, 2015Explorer II
bfast54 wrote:Spartan was very clear that firefighters can bypass the DEF limp and engine shutdowns. The EPA understands that a lack of DEF should not be sufficient reason to disable an engine and PTO especially if a fire engine is pumping water to put out a fire. After all, I'm sure a raging fire puts out more NOx than a Cummins engine at fast idle.
I will wager YOU DO NOT know that "Special Parameters" are BUILT IN to our engine systems that GIVE US CONTROL over parameters ...the UNTRAINED un-needed public engines DO NOT HAVE ....(E.P.A. knows this)...
